From Anonymous on 2014/11/02 18:38:36 +0000
If I set a deep sleep budget of 4hrs, then begin the smart wake-up process. A related feature would be I set an alarm for a specific time, but if the deep sleep budget is reached beforehand, smart-wakeup occurs. If deep sleep budget is not reached, the other alarm goes off.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6651704-create-alarms-based-off-of-deep-sleep-budgets
