New alarms are created using the or by using any of the sleep or nap shortcuts which create a new alarm (with the Delete after ringing option enabled) and start sleep tracking in one step (see Shortcuts)
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//alarms/create_alarm.html
