Coros GPS watch integration
Hi,
I bought sleep for Android and I am happy with it. I use it with Wear OS Smartwatch. I recently bought Coros Apex GPS watch and intended to use it for sleep tracking in the future. Could you please include support for Coros watches in your app? I saw you have support for Garmin and they are pretty similar…
Thanks in advance.
Same here…
It would be great if Coros watches could be supported in Sleep as Android app !
Regards
Hello, I’m afraid there are no APIs we could use for that.. integrating each platform is very big tasks for us - even there are APIs, SDKs or emulators whcih helps lot. Still it is asynchronous communication with two devices with handling of a message queue and lots of states.. normally with APIs we can bring an integration to life in several months.. without any APIs you need heroes like Zdenek Horak who is maintaining the integration with Mi band.. but it is out of our powers to do this.. you need to sniff binary data over BT and every time the manufacturer changes anything the intgeration is broken and you need to start from scratch..
https://support.coros.com/hc/en-us/articles/17085887816340-Submit-an-API-Application
In the API documentation, only workout API is described. Is there a link to sensor API, with direct access to the sensor data in real-time?
