This post is about the constellation of options that control where the sound comes out (“Alarm output”) and how loud it is (volume). Sorry that it will be long
First, the current “Alarm output” menu is misleading. It has 2 options:
- Device default
- Force headphones only
I believe the second option is misleading. It actually seems to get “Headphones if connected, else speaker” (which is what most of us want). Can you reword it?
The first option also seems misleading. It actually seems to get “Speaker only,” rather than what my device defaults to for all other audio apps (headphones if connected, else speaker).
Second, for flexibility, it should really have more options:
- Device default [where is that set, by the way?]
- Headphones if connected, else speaker
- Both headphones and speaker
- Force speaker only
Personally, I want “Headphones if connected, else speaker.” Preferring the headphones lets me avoid bothering people around me if my earbuds are in. (For example, my seatmate or my spouse.) But I need the speaker as a backup if I am not wearing the earbuds, or if they have died or automatically powered off.
However, others might want “Force headphones only,” because they really never want to disturb others. Or they might want “Both” to ensure they hear the alarm even if their earbuds fall out while still powered on.
Third, I should be able to turn off the alarm from the earbuds themselves. This is a safety feature when the alarm is loud and the phone is not within reach. It is also convenient.
Many headphones and earbuds have media controls. For example, clicking my right earbud has the STOP function that will stop the music player or audiobook player. It should stop the alarm, too. Clicking my left earbud has the REWIND function; that should probably snooze the alarm.
Fourth, it’s not safe to use headphones at all without better volume control. You do provide one slider to set the alarm volume – but to avoid damaging my hearing, I would like to set it separately for my earbuds and my phone.
Fifth, for safety, the Gentle Wakeup feature should only go up to the slider’s set volume and no louder! Right now, it ignores the slider’s set volume and goes all the way up to the device’s maximum possible, which is earsplitting and quite dangerous when wearing the earbuds. Already mentioned at [Gentle volume increase up to a certain level] with 76 votes.
Sixth, the slider’s set volume should stay in place. It shouldn’t be affected by the volume buttons as it is now.
At present, if you disable Gentle Wakeup, the alarm will “use current device volume.” But the current device volume was set for my fall-asleep music, or whatever I was doing when I went to bed. The alarm volume should not depend on that.
If my alarm goes off at 8am every day, it should have the same volume every day – with no risk that I’ll screw it up by listening to something at a different volume before bed.
