I regularly switch between two Hue bridges due to travel. Would it be possible to have saved or separate profiles for Hue bridges to avoid having to re-link the bridges? Or better yet, to automatically try each saved bridge?
I think this may have worked ~3 years ago, but I’m sure the implementation has changed since then.
+1 on this one. I often forget relinking the hue bridge when I am in my holiday home. The bridge is in the meter room so quite annoying to have to relink. It would be really nice to be able to link multiple bridges. Right bow, it makes the smart light feature a bit moot.
I noticed this original request was almost 4 years old so probably not going to happen?
