Check if I'm awake!
After a few days of testing it I can say for certain this is all that’s needed and everything works the way I expected.
  • I expected it to not prompt if I dismiss an alarm before it rings,
  • to ring the alarm if I miss the window
  • to continue normally if I don’t.
The only other thing I can think of is an “ask again” option in the notification so that you can either approve that you’re awake or “snooze” the question. But honestly, I can live without that part.
My only question is do I need to manually remove the beta and get the original app from play store to keep getting updates? Or would it automatically update once you release on play store?
