From Wayne Thomason on 2015/09/22 22:36:17 +0000
Wake light currently can only be turned on and off in default settings which makes it active for all alarm profiles.
If the wake light could be set in the alarm profiles, I could set a wake-to-music alarm for weekends where I could listen to a few songs in my playlist without the light coming on. The wake light is great for weekdays but I would like to use it on sleep-in weekends, without going to default settings to turn of the light, risking possibly forgetting to turn it back on before the next weekday schedule.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/9877884-change-alarm-light-so-it-can-be-set-on-a-per-alarm
