Hi!
Would it be possible to cast lullabies on smart speakers such as Google home? If the option to dk so already exists, I couldn’t find it!
Thank you!
Hi!
Thank you!
Hello @Kalquaro, many thanks for your message. This works like any other BT audio routing on your device. You can either ask your Google home to be discoverable over BT and than connect to it. In this case all media currently playing on your phone through the media stream will sound on the Google Home including Sleep as Android Lullaby…
Or alternatively you can use screen casting - you can put a config tile into your status bar to start screen casting… this will also play all media stream audio on the Google home similarly to the previous option…
