From Andrew Pollock on 2015/05/05 23:03:58 +0000
I love using the CAPTCHA in the morning. I have to scan an NFC tag in my bathroom to stop my alarm. It works quite well for me. I’d like something similar to force me off the couch in the evening when I’m in a massive state of apathy and just can’t be bothered going to bed on time.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7841796-captcha-to-go-to-bed
From Rahul Singla on 2015/08/30 03:47:32 +0000
The sleeping alarm should be linked to the wale up alarm . Means if I have set 8 hours as sleep time and my morning alarm is set at 6am then the sleep alarm should automatically activate at 10pm I.e. 8 hours before the wale up time .
From Brett McEwan on 2015/05/11 10:26:27 +0000
You could set an actual alarm around bedtime, with the captcha in your room?
From Matthew Lehmann on 2015/05/09 16:04:32 +0000
If you do this, make it location aware. So if you are at home scan the QR or do sums etc. If you are not at home then don't obviously ![]()
