From Matthew on 2014/11/03 05:12:39 +0000
in order to turn off any alarm I would like to see it so you must use the captcha if enabled to disable it regardless if alarm if going off or not
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6653666-captcha-to-disable-alarm
