Alarm volume in CAPTCHA
Lowers or mutes the alarm volume while solving a CAPTCHA task
During CAPTCHA solving, alarm volume is lowered for 1 minute so that you don’t wake your partner with the ongoing alarm. You can use the 1 minute either to solve the CAPTCHA or get to a different room for solving it.
To get more time, tap on the + icon in the upper right corner
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//alarms/captcha.html
