Running the companion app Sleep Garmin as prescribed.
After waking up, the watch won’t let me snooze or dismiss the alarm and tracking keeps starting again.
When i hold the menu button, the snooze and dismiss option appear, but selecting either doesn’t have any effect. And the app starts tracking again. The only option to end tracking is to shut down and reboot the watch. And sometimes even that doesn’t work.
Steps to reproduce:
See above. Holding menu and selecting option to dismiss alarm has no effect. Sleep as android simply returns to tracking sleep and so does the watch.
Updated December 16th, 2021
Hello @Tristan_Arkesteijn ,
thank you for your feedback. There is a large bug in the Garmin communication API which Garmin refuses to fix for years. Occasionally the Garmin Connect Mobile app clogs up the communication between our app and the watch. In that case, we’ve found out that force stopping and then starting the Garmin Connect Mobile app will refresh the comm queue and then it should work normally.
We tried to contact Garmin on this several times but they just ignore this issue. So our patience just run out now and we have moved to a quite nasty but hopefully fuctional workaround.
We’ve just finished an update of the Garmin integration which uses a different method of communication between the app and the watch, which is apparently working much better than the direct method we used before. We use both of those methods simultaneously and if the old one fails, we switch to the new method. From our tests, this has good results and we haven’t had any missed data in any night we’ve been testing with this.
On Vivoactive 3, we’re also seeing around 15% battery drain per 8h of tracking (with HR/HRV on).
If you want to try this, you’re going to need two things - a new Garmin addon for phone, and a new watch app. Both of these are currently labeled as beta and not published for general availability. So to try it, please follow the steps below.
- Get beta of the phone addon:
- Register for beta testing of the Sleep as Android Garmin addon here >> https://play.google.com/apps/testing/com.urbandroid.sleep.garmin
- Make sure the beta update gets downloaded on your phone.
- Get the updated watch app
- First uninstall the Sleep app from your watch using the Garmin Connect app ( Garmin Connect > tap on your watch > Activities & App Management > Activities & Apps > Sleep > Uninstall )
- Download the .prg file for your watch model in the list here: Garmin beta watch app - Sleep as Android.
- Connect your watch to your computer via USB. Put the .prg file on your watch in /GARMIN/APPS folder (just like you would put it on a USB drive).
- Run Sleep on your watch!
Please let me know any thoughts or feedback you’d have about this.
Thanks @petr-urbandroid! Only saw this just now due to a very busy time at work.
Will try the beta route and let you know!
Best, Tristan
@Tristan_Arkesteijn many thanks, please let us know, we already have some encouraging feedback from other users in the BETA..
