The alarm can get dismissed when at home without scaning the QR. The location feature is not working.
Hi Marco, welcome to the forums!
What device are you running SaA on?
Do you have another device to check if the location problem is specific to the device you’re currently using?
Hello @marcojurado, also please use menu > report a bug and send us the report, maybe the app is just unable to detect your location properly. Is the location service running? Did you grant the location permission to the app?
