Calendar #tags control specific alarms
From John on 2016/09/10 21:22:20 +0000
Thanks for a great product!
I use Google Calendar integration to great effect - particularly the automatic advancing of alarms - awesome feature!
I work shift work, and have random days off.
The #holiday feature is great, but it switches off all the alarms. I would still like to have an alarm set for my days off, although at a more relaxed time.
It would be great to be able to have an alam called “morning shift”, another called “afternoon shift” etc … and one called “day off” … and then, with tags in google calendar title or description for each of these events, enable the correct alarm and skip the others for that day.
Another app I used to use for controlling phone features did something similar based on tags in the title or description of calendar events.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/16005592-calendar-tags-control-specific-alarms
