Create alarms based on calender events rather than specific times by using tags.
E.G. new alarm that activates based on calendar events with #work in the description, with ability to choose how many minutes prior to the #work event the alarm sounds. So regardless of different work start times each day, one alarm can be set to automatically update and sound 60 minutes prior to each #work calendar event.
This is a great idea. Presently I use AMDroid for the Calendar based alarms. It is very helpful with my work “schedule”.
