Calculation of Duration wrong
Since a few days&weeks the calculation of the duration seems wrong
Steps to reproduce:
Start Sleep Tracking
20200828!
Screenshot_20201007-175014__01|290x499
Did not reset/reinstall the App so far.
Thank you in advance.
Hello, I did quickly overlooked the graphs and to be the calculation seems ok… You have several awake episodes in each of the graphs and awakes are subtracted from the total sleep duration.
If you think the awakes are not detected properly, you can configure the awake heuristics sensitivity in detail in Settings > Sleep tracking > Awake detection…
If you send us a menu - report a bug, we can have a look what heuristics are causing the most awakes…
Thank you @petr-urbandroid for clarifying, will check the awake detection.
