Break down sleep noise
From Anonymous on 2017/12/09 11:43:08 +0000
Put sleep noise into category so I can choose to listen to each section individually instead of having to listen to everything. I sleep talk alot so would be beneficial to choose just to listen to those moments instead of searching through hours of teeth grinding or snoring
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/32568103-break-down-sleep-noise
