From Maxence Leduc on 2014/11/07 00:45:41 +0000
Hi,
with more and more Bluetooth speakers, my suggestion is to add an option to turn on Bluetooth some minutes before the alarm, for the sound to come from my Bluetooth speaker
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6677742-bluetooth-auto-activation
From Anonymous on 2014/12/05 12:07:00 +0000
There was the option to force headset and if bt was turned on the alarm came on via bt speaker under my pillow never woke my partner it was awesome but I didnt use it for a couple of months and now I cant find that feature : (
From Petr Nálevka on 2014/11/07 11:56:51 +0000
It depends how sensitive you are about the wireless radios subject, but BT is the least intensive radio of the radios you have in your phone.
Also this could be achieved with automation using for example Tasker or Reactor..This is documented here:
