From Danny on 2018/02/27 13:23:14 +0000
Currently the “prevent escaping captcha” is not very useful because you can very easily just disable the app as administrator and then force close the app.
How about instead when the alarm starts to ring, the app records that an alarm is starting to ring, and when the captcha is “solved” it also marks the alarm as properly dismissed.
However if the app opens up and finds that an alarm started to ring but was not properly dismissed it will require the user to do something as punishment before using the app again or setting another alarm
options:
- can’t use the app one or more days
- need to donate money to devs/charity
- could work as you no longer have access to the paid version of the app, and need to pay again to get the paid version
 Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/33465793-better-prevent-stopping-alarm-if-set-to-use-captch
