Best watch for Sleep As Android
So which smart watch (any manufacturer) is the best for Sleep As Android nowadays? I’m currently using an Amazfit Band 5 and it works flawlessly. It seems like manufacturers are actively blocking SaA with new releases, as the Band 7 or newer watches to not let full support.
The most important feature for me is vibration for alarms.
Hello @JiggyDancer .. you may have a look at We finally have a new king of smart watch! - Sleep as Android but in general integration with Zepp/Amazfit/Mi Band is all reverse engineered as those device do not provide any developer APIs, this is a hard work of the brave devs of Tools & Mi Band or Notify & Fitness.. Of course as the manufaturer does not care about integration they usually break integration with each new release and the aforementioned heroes need to try to integrate again.
@petr-urbandroid thanks for the link to the review, unfortunately, another review says completely the opposite.
@petr-urbandroid could we get any update on this? Is it still the Tic Watch 5 as posted here? We finally have a new king of smart watch! - Sleep as Android
What about pro 5, atlas, pro 5 Enduro, or other brands?
Could this list get updated by any chance? Supported wearables - list - Sleep as Android
Thank you and Kind Regards
