Hi
What’s the best supported smart ring?
Thanks
Hi
Thanks
Hi @Isnull, so far, there is no ring with an open API for integrations. If you know of any smart ring with an open API (an access to the sensor data, not only some cloud API), please let us know.
Btw Samsung health told me you guys should fix the issue about HR not showing in SH. ![]()
Hello, which issue with HR do you have?
What is the source of the HR data? What is the source of the HR data in the S Health, that were not synced into Sleep graphs?
We had an issue with HR data sync reported, but it was not to Sleep, but from S Health to/from Health Connect.
