The SAA app keeps creating a folder called ‘sleep’ in my music folder and saves the ‘best of noises’ tracks to it and I don’t want that and I tried deleting the ‘sleep’ folder and resetting the ‘storage path’ in the ‘sleep noise analysis’ page and it stops it from being saved in my music folder for while but it keeps coming back after some time.
Steps to reproduce:
Have sleep noise analysis turned on and track sleep and check music folder for a folder called “sleep’“
Hi @paisano, the app uses the Android media library for starred files, which can send a copy to Google One. The starred files are the ones we assume you wish to keep.
Are you using the star system to mark some of your files?
I just was just checking and some were files were indeed marked with the star, so I may have accidentally pressed on the star while skipping tracks since the star icon is beside the skip button, sorry!
We were discussing it in the team, and decided to add this as an option. If the file is starred by mistake, it can be undesirable to share it. We did not think about this scenario before.
So in the next version, there will be an option to completely turn this feature off in Settings > Sleep Noise Analysis.
If you are interested in getting the version soon, it should be in the BETA testing channel tomorrow.
