Best device for lucid detection
Can you advise which best device works well with the SSA lucid detector? My mi band 6 does not vibrate in this mode (((
To make Mi Band integration work with Sleep as Android you need to install Tools & Mi Band or Notify & Fitness apps.. than mi band will vibrate during REM when the lucid dreaming option is enabled. If this is nt the case for you please use menu > Support > Report a bug..
