Battery usage Pixel 3 and Amazefit5
Last night I used 40% battery sleeping actual 9.5 hours. This seems like more than before. Is this normal.
I use an amazfit5 and it doesn’t use that much battery. My galaxy is plugged in.
I us Notify and Amazfit without the official amazfit app.
The notify app tells you how to use it without the official amazfit app (which is terrible).
I think if you type in free my amazfit or free my mob and it gives you instructions as well.
Maybe you have your amazfit checking you HR too often?
  1. No settings changed except for the update of SasA.
  2. I think there are different issues between a Galaxy and a Pixel 3.
  3. I have had a couple of more nights with over 40% usage during sleep.
    Last night I went to bed at 12:30 with 45% battery. I could not get to sleep and got up from 1:30 to 3:00 without stopping SasA.. I then slept till 11:00 a.m. when I had 1% battery as my phone died as I looked.
    I would be glad to supply any logs or information to assist in this check.
