3% to 5% of battery used by Sleep during the day, even though the auto sleep detection is off and time to sleep alarm is off too. This is not ok.
Release 20260313, Android 15
Hi @KeeRah, how long has it been since you noticed this issue?
Is the Sleep Time Estimation feature enabled? Could you please reboot the device in the morning, and in the evening send the screenshot of the battery stats and the logs from the Sleep app (Left ≡ menu → Support → Report a bug)? Thank you.
Thanks for the reply.
It’s a new phone, and it started right away after I moved Sleep from my old one. I noticed immediately because Android keeps notifying me about the battery draining by Sleep. Sleep time is disabled. I have other much more hungry apps running in the background, but they do not act like that. Will try to gain more info.
How much battery is reported for 24 hours, including sleep tracking? Is the 3-5% battery consumption after the tracking ends till the evening?
