Expand the app’s automation Intent API to support creating, modifying, and deleting alarms, rather than limiting intents to status changes (activated/deactivated) only.
This would unlock advanced, schedule-dependent automation routines (for example, alarm adjusting to changing local sunrise times).
Support conversation
I would like to have Tasker integration updated so Tasker could create and delete alarms in the Sleep as Android.
support conversation with Kalle
For the automation component of the app, is there any plan/possibility to include setting alarms for a specific time via MQTT, app intents, or Tasker?
This would be an absolutely game-changing addition to the smart home scene; especially thanks to SAA’s addition as an official Home Assistant integration, some ability to set alarms via MQTT push or a Tasker action for example so I don’t have to always directly interface with the device running SAA would be stupendously helpful for myself and I believe many others.
support conversation with Shem
