From SimTech on 2016/10/11 20:53:17 +0000
The “Do not disturb” feature on my Galaxy Note Edge works great for me and lots of phones have such a feature. Why not have an option to enable it after the phone sends its bedtime notification.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/16608694-automatically-turn-on-do-not-disturb-feature-bui
From Petr Nálevka on 2017/03/10 10:28:04 +0000
+Anon we have DND after sleep tracking starts, but not yet after bedtime notification..
From Anonymous on 2017/03/10 07:41:05 +0000
I see this feature in my option menu when using the app. If this is an old feature suggestion that has been implemented it should be removed
From Taylor Carroll on 2017/02/22 06:31:16 +0000
I always have Do Not Disturb mode on, 24/7. All you have to do is go into the DND settings and allow app notifications (you can select which apps to break through and notify you). Problem solved ![]()
I can’t find an option how to set DND after sleep tracking starts. There is only an silent mode which will be enabled if sleep tracking starts, but I would need to set the really “Do not disturbe”. Only in this case I can stop to get messages on my mi band 4. Or can someone write me which options I should set on MI band notify to stop to get messages when sleep tracking starts?
