Audio Timer (+delayed audio recording)
From Hausie on 2015/11/06 07:46:18 +0000
Same use case as here http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/9864117-option-to-not-record-noises-while-audio-is-playing
But it would be actually great to if there was even deeper integration (a bonus feature?) for the use case of falling asleep with audio - A sleep timer integrated directly to Sleep as Android.
  • stop/pause external audio app after defined time
  • start snoring recording after defined time
  • have some “extend” and possibly “stop now” buttons on the tracking screen
  • ideally keep non-audio-tracking on during the timer time
I’ve used several third party timers to turn the audio off after some time, and some even prevented Sleep from going off.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/10574823-audio-timer-delayed-audio-recording
