Helps you (or your partner) fight snoring.
When enabled, Anti-snoring looks for snoring sounds while you are sleep tracking and will react and try to make you stop snoring.
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/sleep/anti_snoring.html
Would love the ability to control which device does the anti-snoring alarm. I don’t want to wake my partner so it would be ideal if I could get my watch to vibrate and not my phone
Hi @Sleepyjoe1, only one device vibrates. If a wearable is connected and used for sleep tracking, the app sends the vibration intents only to the wearable.
The preview vibrates with both devices, but the real life anti-snoring will only vibrate with a connected wearable.
