Anti-snoring - Sleep as Android
Helps you (or your partner) fight snoring.
When enabled, Anti-snoring looks for snoring sounds while you are sleep tracking and will react and try to make you stop snoring.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/sleep/anti_snoring.html
