Amazfit Helio Strap
Does it work work SaA and what’s tracked? Does SaA smart alarm work with it?
Hi @RonAsleep, Amazfit devices have a closed platform, so we cannot design direct integration. The only way to use Amazfit is via one of the two companion apps - Tools and Amazfit.
Which one do you use?
Hi! I’m looking for a replacement device since my Scosche Rhythm24 doesn’t last through my sleep cycle. I’m considering Polar Verity Sense in addition to Amazfit Helio Strap and Polar Loop. I’m mainly looking into getting more accurate HRV compared to the Garmin Forerunner 165. The readings from HRV info from Forerunner 165 seems inconsistent compared to the Rhythm24, if that makes sense.
Would the Verity Sense be a better replacement for the Rhythm24, instead of Helio or Loop?
Polar wearables are great quality products, in general. Polar Sense is compatible, and Polar Loop is currently not compatible (only some models are compatible via BT and some via the Polar SDK)
We do not have any experience with Helio Strap; it does not seem to be supported by the companion apps, so probably not compatible at all.
Thanks! Appreciate your insight.
