Amazefit bip 6 integration
hi
will amazefit bip 6 integrate with sleep app
Hi @Prannab, Amazfit wearables do not allow direct integration. So we will integrate Amazfit Bip 6 only if Huami allows it.
The current integrations with some Amazfits work only thanks to the help of the companion apps (Tools or Notify), which overcome the missing API and technical limitations. Not all models were possible to integrate.
Which companion app do you use?
hey @lenka-urbandroid thanks for quick reply.
im planning to buy amazefit bip 6.
earlier had redimi lite 5 , it was good watch but the integration were limited even by notify for mi app.
any suggestion whether i can go with bip 6?
thanks in advance
HI, Notify app supports Bip 6. There might be some limitations - this is due to missing options for direct integrations. The Notify app cannot link directly, they use highly advanced techniques (like BT sniffing and tons of hacks) to read the data blocked on the Amazfit platform.
@lenka-urbandroid in the list of supported device in ur website - amazefit bip6 is supported, just wanted to know will the sensor gets integrated via notify app?
in my previous experience with redimi watch 5 lite the sensor donot work though it shows graphs for few mili seconds and then all straight line
Kindly let me know
Thanks
Yes, the Amazfit Bip 6 is listed as supported in the Notify app section, because we can access the data only via the 3rd app.
The list in our docs was approved by the Notify developer.
Only some Redmi Watch models support sensor data reading, Watch 5 Lite is not one of them. The newer the model, the harsher the technical limitations for non-official integrations, sadly.
