So few days ago I set alarm to 6PM instead of 6AM, I think would be cool if on tracking screen be warning like hey are you sure …
Thanks!
Thanks!
Hi, would using the 24 hour time help prevent this?
How the warning should be configured? Like a check if you are tracking and the alarm is too far away? Should it be on a tracking screen?
The app shows a toast how long till the alarm, when you create one - does this count as a warning, or is it not prominent enough?
I believe not, I had to miss toast, it’s my fault but still. I would say that it still can be improved.
The 24h clock might not be something what I want to use.
Hi, one last question - did you use the wheel time picker? I was wondering, if the confusion might have been prevented directly on the alarm time picker.
