Threshold volume is set too high, so only very loud sounds meet the criteria for recording, and only a few will trigger the recorder.
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/faqs/almost_no_recording.html
После первой ночи в режиме мониторинга сна со снятием параметров с часов Galaxy Watch 8 и подключенного к зарядке смартфона Samsung Galaxy S24 приложение вообще не записало храп, но записало подкаст с YouTube, который проигрывался в первый час после засыпания. Между тем, программа Samsung Health записала 2 часа храпа.
Hi @Dmitry2, since only one app can use the mic, if you used the S Health app to record snoring, our app could not have access to the mic at the same time.
If you pause the S Health app sound recording, will the Sleep app record more sounds, even during the night?
