From KAI on 2014/10/16 08:51:33 +0000
Settings->Sleep tracking->“Silent mode when tracking” is a very appreciated feature. But I would like calls to still ring even when all other notifications are disabled.
I just want people to be able to reach me when it is really important.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6568470-allow-calls-to-ring-even-in-silent-profile-mode
From Robert on 2016/06/01 01:08:16 +0000
I don't want to install other software just for this feature.
If possible I just want a whitelist of up to 5 people / numbers that can call me, no matter what the status of the alarm.
From Moritz Sauter on 2015/04/15 20:33:06 +0000
Isn't it easier for the sleep App to achieve that with the new notification mode of Android L?
Maybe a switch or a config where you can say the mode should be 'only important' and not 'nothing'.
Correct me if I'm wrong.
From Petr Nálevka on 2015/01/08 15:26:06 +0000
+Robert there are planty of call blockers on the Play Store, I did not try them out, but wouldn't this address the issue. Also in Lollipop the app cannot set you to silent mode any more, so we use a priority mode - vibration, which may also work well for this use-case I guess? Thank you
From Robert Hill on 2015/01/08 14:20:12 +0000
I agree with this suggestion. The only thing I do not like about this app is that in the event of an emergency it makes me practically unreachable. It would be GREAT if there were a whitelist for certain calls to ring through.
