Most likely, your Backup alarm went off after your regular alarm failed tp wake you up. T Backup alarm is triggered when there is no interaction (no snooze, no dismiss) for more than 20 minutes.
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/faqs/alarms_play_at_max_volume.html
