Alarms do not play selected ringtone - Sleep as Android
If the service is not responding for too long, the app will use a built-in ringtone. If the alarm starts and your phone is locked we are unable to change the playlist or album in your Spotify app. In this case the app will simply play where you last left it.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/faqs/alarms_do_not_play_selected_ringtone.html
For Sleep as Android alarms, if the service doesn’t respond, the app defaults to a built-in ringtone. Also, if your phone is locked during alarm, Spotify settings can’t be changed.
