Alarm without sounds required
Is it possible to configure an alarm without any sound, just with vibration?
Thanks.
It is! Just set the ringtone on the specific alarm to ā€˜Silent’.
To get to the individual alarm settings, tap on that alarm in the list of alarms (left menu > alarms, or tap on the alarm card). You can also set this while creating a new alarm.
I was trying to configure the default alarm. Very clear your explanation.
Thank you.
It’s not possible to set a silent ringtone as the default. This is a safety measure to prevent people from unknowingly setting all their alarms to silent and oversleeping.
Hi. Isn’t there really a workaround for this? I’d like to use the automatic ā€œideal sleep timeā€ alarm, but really wanted it to be silent by default (I rely on my smart band and a QR captcha to make sure I get off bed).
Thanks
