Alarm tone is loud ringing instead of spotify
Three times recently (today, yesterday, and about 2 weeks ago) my morning alarm has been a loud ringing tone instead of the ‘current spotify playlist’ it’s meant to be. Spotify seems to open correctly, but doesn’t play, then after a long delay the app just makes a jarringly loud ringing noise. I can’t find a setting to disable this, or any reason why spotify won’t play. It’s not a pleasant thing to wake up to.
Steps to reproduce:
Honestly, no idea. I haven’t changed anything from my usual settings that (generally) have worked fine for as long as I’ve had the app.
Can’t find the number but it updated 10 hours ago
Many thanks for the report. We have found the root of the issue and it will be fixed in the next beta, including some added features to the Spotify integration!
I think I have the same issue (you see the spotify app openning but anyway it plays a default song from the phone in place of using spotify).
Do you know when the fix is going to be available in the stable version? to know if I should wait for it or install the beta app
I experience the same issue. I woke up to the secondary alert. The interesting thing is, that when I re-enable the network, the Spotify do start the playlist. Of course the playlist is downloaded. By the way, I found the following discussion, maybe this is relevant here: “Tasker cannot start a Playlist anymore, Send inten… - The Spotify Community” Tasker cannot start a Playlist anymore, Send inten... - The Spotify Community
To avoid the errors, you may think about using the Spotify Downloader. It helps you save the songs on your players or other devices. You can set the music as alarm and also listen to the songs without errors on your devices. That means you can control the music’s playback on your devices.
Try to reinstall the app and have a try. Or you can use a Spotify to MP3 downloader like TunesKit Spotify Music Converter to download Spotify songs to MP3. And set Spotify as alarm. It will solve this problem.
