Advice - Sleep as Android
Advice shows your current sleep development at a glance.
You can see which dimensions of your sleep have improved or worsened recently, including tips on how to reverse the worsening trends.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/sleep/advice.html
