From Anonymous on 2016/12/25 08:13:04 +0000
Be good to adjust the vibration level in lucid dreaming
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17541508-adjustment-for-vibration-level-on-watch
From Petr Nálevka on 2017/08/30 12:04:25 +0000
+Yuri… you can do that, if you turn off vibrate in Lucid settings your watch won't vibrate…an you can use Automate to vibrate on the phone if you need that…
From MonZon on 2017/08/30 11:36:23 +0000
Or at least ability to turn it off completely for wearables, so we could use Automate or Tasker to customize vibration strength and pattern.
From Petr Nálevka on 2016/12/28 11:09:03 +0000
You can adjust number of repeats, but I think on most Android devices there is no vibration intensity only length…
