With the app for Sleep Phaser you can choose the color of the light. When you switch the Sleep Phaser on with the app, it works and the light has the color you have chosen. If you switch the light on at the Sleep Phaser itself (by touching), the color always stays the same, no matter which color you have chosen with the app. Is it possible to fix that? Would be nice if it’s the color you have chosen with the app too when you turn on the light by touching Sleep Phaser itself.
from support conversation with Markus
