Add shuffle option for spotify
Hi! Spotify alarm is a one of the best things that were happened with “SaA” (imho ofc) =) But there’s still no “shuffle” option =( Tried daily updated playlist with chill house - now they are not “daily updated”… so now i’m listening one song every morning
Please, If it’s possible - add “shuffle” option for playing spotify playlists
Yes, i know that i can choose “current playlist” in alarm settings and manually enable shuffle in spotify, but this is not really convenient option )
Hello @s1mptom.. many thanks for your feedback.
I do not think we can implement this.. what we do now is we ask Spotify to play a particular playlist but we have no control over the playback order, this is done by Spotify. Sorry about that..
yeah, I thought so
that’s sad) gonna try to find some workaround for my problem..) thanks for your reply and your work) have a good day!
There is a far from ideal workaround :slight_smile: - cancelling premium which will shuffle everything :).. I was also thinking that in fact the non-premium shuffle mode may be seen as a feature in some cases.. I do not understand why playlists play always in order in Spotify premium so for instance playlists I use for certain occasions always start with the same songs first which is annoying..
found some solution with tasker and autoinput =) not the best… but it’s something)
Hello @s1mptom, can you please share few more details on how this works? You are similating touches with autoinput? I guess this is root only?
I found a way to start a shuffled playlist of your choice when the screen is locked and/or off, no root required. You need Tasker, Autoinput and Secure Settings.
First check if the screen has to be turned on and launch spotify on background:
if %SCREEN eq off
 Plugin - Secure Settings - Configuration - Actions - Wake Device - Screen & Keyboard Lights on / 5 seconds
 Wait 100ms
 App - Launch App - Spotify
 Wait 500ms
end if
Then send the intent to open spotify playlist (this happens behind lockscreen):
System - Send Intent
 Action: android.media.action.MEDIA_PLAY_FROM_SEARCH
 Cat: Default
 Data: spotify:user:<userid>:playlist:<playlistid>
 Package: com.spotify.music
 Target: Activity
Directly after configure the AutoInput (run in foreground) action to shuffle play:
 Type: Text
 Value: SHUFFLE PLAY
 Action: Click
 Timeout: 1 sec
found this on spotify forum but didn’t try yet
another clue - i’ve found spotify app remote lib Spotify App Remote
there’s something about shuffle class but i’m not a java dev so…=)
upd.
asked my colleague about this) he told me that - yes you can enable shuffle using this lib)
That would be a great feature!
When I select a playlist I end up listing to the same song every day.
I’m not sure if that helps, but the alarm on the Google Clock app shuffles by default when set to play a playlist from Spotify.
Hello, unfortunately the the Spotify API does not have a shuffle option, but you can specify more individual Spotify songs and use the shuffle play mode of Sleep as Android.. would that work?
I see, I’ll give it a try, thanks for the suggestion.
Can you take another look at implementing this? I’ve found a way to do it on Alexa.
In a routine , in the ALEXA WILL section I wrote:
Play “Shuffle my playlist [Morning Wakeup]” on Spotify for 1 hour 30 minutes
I paid for your app, and if you add this feature I would be able to recommend it to friends. As is… I don’t actually use your app to wake me up anymore. I prefer Alexa shuffling a custom playlist I made . It’s sad :frowning:
