From David on 2018/02/02 16:57:08 +0000
Could you please include a feature that allows the dream detection for lucid dreaming cues to be set and start at a certain time into the sleep cycle? Certain lucid dreaming techniques suggest that “wake” cues occur 6 hours or so into the sleep when REM/dreaming periods are longer. Not that the cue itself would occur at the time set, but that the detection would start at the set time.
Another advantage of this would be a more targeted wake cuing. As it is, “You are dreaming” will occur at any time in the sleep cycle, every time REM sleep is detected, which can be quite disturbing to the sleep cycle. Setting the time detection is to begin will alleviate this problem.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/33183796-ability-to-customize-dream-cycle-detection-for-the
