From Anonymous on 2014/12/10 19:58:55 +0000
My problem is technical: the charger’s cable is not long enough for the phone to be placed on the bed (so it doesn’t make sense to turn on sleep tracking). I like the lullaby feature, but I don’t want it running all night long (so using the demo is not and option either). Instead, I would love to be able to set in advance a duration for which the lullaby would play before it fades out, and maybe a snooze-like option to extend that period.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6827282-a-timer-for-selecting-in-advance-lullaby-duration
I also would like to set a timer for the lullaby. I don’t want it to run all night. Please enable this basic functionality.
Hello Matt, the timer for lullabies is in Settings > Lullabies > Turn off when sleeping. This timer is a minimum duration of the lullaby playback, after this time is over, the app will gradually lower the volume to zero if it detects you started to fall asleep.
