When you’re looking for a new road bike, you have a lot of options. You can spend thousands of dollars on a high-end model or get something that’s just as good but much cheaper. But if you want to save money and still get a quality ride, there are some things to keep in mind when deciding which one is best for your needs.
First off, look at the frame size. This will help determine how much weight your bike can support and how comfortable it will be for you. If you’re wearing compression socks during long rides and find yourself getting sore after every few miles, then consider getting a smaller frame size; if not, go with something larger so that you don’t have to worry about hurting yourself while riding!
Another factor is how many gears your bike has–this will help determine how fast or slow it can go depending on how much power is needed at any given time and how often gears need changing while riding (which could compromise performance). If this sounds important to you then consider getting an extra gear so that there’s more room between each turn without having to change gears constantly while riding (which can cause fatigue).
Finally, consider what kind of riding style best suits your needs:
