Wake up softly with simulated sunlight!
#1
From Will “Fl4sHNoX” Spartan on 2014/10/29 19:16:01 +0000
Simulate the sunrise with the light of the smartphone screen when it’s going to wake you up.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6632531-wake-up-softly-with-simulated-sunlight
#2
From Michael on 2015/04/14 21:06:19 +0000
That's what i'm searching for, maybe like your Twilight App but in the other way?
#3
From Horst on 2015/02/01 07:18:01 +0000
I'm tracking sleep with my tablet, and i have no flashlight. I sleep often in hotels, where i got no smartlight-bulb. I would LOVE to have the option to use the max brightness displaylight as sunlight-alarm BEFORE the sound starts. (For example: start the displaylight on alarm time and 1minute after that start raising alarmsound volume. Thx for this great app!
#4
From Will “Fl4sHNoX” Spartan on 2014/12/04 18:06:54 +0000
Not everyone can/want to use the Hue Lighting to be able to have this kind of functionality :confused:
#5
From Jeremy on 2014/12/04 05:47:24 +0000
Dim to off, brighten to full light. The Hue lighting is much more capable than the app allows it to be.
#6
From Will “Fl4sHNoX” Spartan on 2014/10/29 23:07:40 +0000
Update: seems to work for me but it's not really what I search for, a little bit agressive at waking up ^^', anyway that's why I thought that this "wake up with soft light feature" could be a good one. =)
#7
From Will “Fl4sHNoX” Spartan on 2014/10/29 23:02:31 +0000
OK, thanks I'll see if this works ! =)
#8
From Petr Nálevka on 2014/10/29 22:44:25 +0000
In settings > alarm > very bottom… Please note that this feature may cause crashes on some firmwares…
#9
From Will “Fl4sHNoX” Spartan on 2014/10/29 21:12:36 +0000
PS: I saw the compatibility to control Philips HUE but I didn't wanted to buy one yet so I thought that this could be an idea for people who don't want to buy one like me =)
#10
From Will “Fl4sHNoX” Spartan on 2014/10/29 21:09:51 +0000
Thanks ! =)
But I didn't find the ability to wake up with flash light, can you tell me where can I find it ?
Many thanks ! =)
