I’m having a hard time figure out all the features.
What exactly does “postpone next alarm” do? Set the alarm for so much time later or earlier than the time selected?
Hi, it’s great that you ask
I’ll show an example:
I have an alarm set to 7:00.
Postpone +1:00 means that the next alarm will sound at 8:00.
Postpone -1:00, will make it ring at 6:00.
It’s really the simplest it could be
