Post-wakeup monitoring
#1
From Norman on 2014/10/13 15:44:49 +0000
An optional feature to continue monitoring after turning off the alarm would be great. So that if the device has not been moved within (configurable amount) minutes after the set alarm a safety alarm would go off.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6556462-post-wakeup-monitoring
#2
From Matej dro on 2015/04/21 09:56:57 +0000
Is there a reason to keep monitoring after the alarm at the moment?
#3
From Brett Rusnock on 2015/03/31 21:20:49 +0000
I think this is a great idea. I previously used Puzzle Alarm Clock by Wro Claw Studios (https://play.google.com/store/apps/details?id=com.wroclawstudio.puzzlealarmclock) and they had a neat backup alarm option. It would pop up a notification on your phone 5 minutes after your primary alarm is turned off. If you don't address the notification within another 5 minutes, it sounds the alarm again. This process continues indefinitely, or at least until you get out of bed and address the notification.
#4
From mette on 2015/01/25 13:12:13 +0000
Or that it would be optional to turn the sleep-monitoring off manually. So that whenever my alarm is set, the sleep-monitoring cintinues until I close it.
#5
From Doug on 2014/11/18 05:57:47 +0000
Please add this! At least as an add on feature
#6
From Anonymous on 2014/11/16 03:31:27 +0000
Yea, and if this larm triggers play up hornet sounds
#7
From Anonymous on 2014/10/29 01:32:52 +0000
Yeah but i turné off alarm and ho to shower (my iPhone still on bedside table eithout any move
#8
From Cory Richter on 2014/10/17 06:37:44 +0000
This would have been useful other day when I turned off alarm and fell back asleep
