More complex lullabys
From Matyas Ondruska on 2015/04/26 21:09:44 +0000
Some lullabys are scary to listen (chanting monks,whale etc…) to and some are just too short ( piano, cat purr, lava lake) these latter would be my favourites but they are so short that instead of falling asleep I get annoyed listening to the same 5 sec music over and over again.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7714962-more-complex-lullabys
From Petr Nálevka on 2015/10/16 12:07:45 +0000
@Daniel
  1. app size limit is not the problem, but people prefer small APKs, this is very important to a group of users
  2. This would require hosting a back-end service for quite big data - this would introduce significant monthly costs, you know that our concept is a one-time purchase for a lifetime…
From Daniele Segato on 2015/10/08 12:02:53 +0000
App size limite has been recently doubled to 100 MB
Also you can download the lullaby after install to overcome any size issue
From Anonymous on 2015/08/27 06:25:42 +0000
I fall asleep to the whales??
From Cat Burden on 2015/07/16 04:36:32 +0000
This could be improved with limited the limited space requirement be randomizing a set of sounds that can flow into each other of work well with pauses in between. This is similar to how ambience in games works.
From Petr Nálevka on 2015/06/30 14:12:54 +0000
+Thomas… you can use any music on your device as lullaby played with your favorite player and sleep as android will take care to turn down the volume as you fall asleep just enable "Turn off when sleeping" in settings>lullaby…
From Thomas Grumet on 2015/06/30 11:24:09 +0000
Custom lullabies using personal music already on the device
From Rafał Zastróżny on 2015/05/25 21:35:54 +0000
For You are scary for me is relaxing
From Erik Klein on 2015/05/04 19:29:06 +0000
Actually that might be a good idea. The song flute is really weird.
